1. ホーム
  2. ドキュメント
  4. 2. Initial Use Case Model...
  5. 2.3 Visualizing the Model
Instant Generation of Use Case Diagrams to Represent System Functionality Visually
A picture is worth a thousand words—especially in requirements engineering. After brainstorming actors and goals (2.1) and curating a solid list of candidate use cases (2.2), the most powerful next step is to see the system’s functionality at a glance. This is where the Use Case Diagram shines: it provides an immediate, high-level visual overview of who does what with the system, clearly defining scope and responsibilities without drowning in details.
In traditional modeling, creating a clean, professional Use Case Diagram could take hours of manual drawing, alignment, and iteration. Visual Paradigm’s AI-Powered Use Case Modeling Studio eliminates that friction: with one click (typically labeled “Generate Diagram” or “Visualize Use Cases”), the tool automatically transforms your curated candidate use case table into a polished, standards-compliant UML Use Case Diagram.
Key features of the AI-generated diagram include:
  • Actors shown as stick figures (or system icons for external systems)
  • Use cases represented as ovals with clear, concise names
  • System boundary rectangle enclosing only what’s inside scope
  • Automatic layout for readability (no overlapping lines or crowded elements)
  • Consistent styling matching UML 2.x conventions
  • Immediate export options (PNG, SVG, PDF) for stakeholder reviews or documentation
You retain full editability: drag to reposition, rename elements, add notes, change colors, or modify relationships—all while the diagram stays synchronized with the underlying use case list.
Practical Examples
Example 1: GourmetReserve – Mobile Dining Reservation App
Inputs fed to the generator:
  • Actors: Diner, Restaurant Staff, Payment Gateway, Notification Service
  • Selected use cases from the candidate table (high/medium priority):
    • Search for Available Tables
    • Book a Table
    • Pre-order Meal
    • Cancel Reservation
    • Receive Booking Reminder
    • Manage Reservations
    • View Pre-Ordered Meals
    • Process Payment
What the AI instantly generates:
  • A rectangle labeled “GourmetReserve Mobile Application”
  • Left side: Diner actor connected to five ovals (Search for Available Tables, Book a Table, Pre-order Meal, Cancel Reservation, Receive Booking Reminder)
  • Right side: Restaurant Staff actor connected to Manage Reservations and View Pre-Ordered Meals
  • Bottom: Payment Gateway connected to Process Payment
  • Notification Service connected to Receive Booking Reminder (showing system-initiated notification flow)
  • Clean, balanced layout with no crossing lines
Typical refinement you might make:
  • Add a note near Book a Table: «includes» Process Payment (after deciding payment is mandatory)
  • Color-code Diner use cases in blue and staff use cases in green for quick visual separation
This diagram immediately communicates: “Diners interact for booking and convenience; staff manage operations; external systems support payments and notifications.”
Example 2: SecureATM – Next-Generation ATM Network
AI-Generated Diagram Highlights:
  • System boundary: “SecureATM System”
  • Left: Retail Customer connected to:
    • Withdraw Cash
    • Check Account Balance
    • Transfer Funds
    • Deposit Check
  • Center: Small Business Owner overlapping with Retail Customer for shared use cases (Deposit Check)
  • Right: Bank Operations Team connected to:
    • Replenish Cash Cassettes
    • Monitor ATM Status & Alerts
  • Bottom: Fraud Detection System connected to Analyze Transaction (often shown as a secondary actor)
  • A small oval “Authenticate User” placed centrally, with dashed «include» arrows from Withdraw Cash, Transfer Funds, Deposit Check, etc., pointing to it (the AI may suggest this foundational reuse automatically if it detects the pattern)
Visual impact: Stakeholders instantly see that customer self-service goals dominate the front, while operations and security are critical but separate concerns.
Example 3: CorpLearn – Corporate E-Learning Platform
AI-Generated Diagram Snapshot:
  • System boundary: “CorpLearn Platform”
  • Left side: Employee actor linked to:
    • Enroll in Available Course
    • Complete Learning Module
    • Take Final Assessment
    • View Progress & Certificates
  • Right side: HR / Training Administrator connected to:
    • Upload / Update Course Content
    • Assign Mandatory Training
  • Top: Manager actor connected to View Team Training Progress
  • Bottom: Compliance Officer connected to Generate Compliance Report
  • Optional: External SSO Provider shown as secondary actor connected to Authenticate User (if included)
Common post-generation tweak:
  • Add «extend» relationship from Take Final Assessment → Request Certificate (only for passing learners)
  • Group employee use cases inside a package boundary labeled “Learner Portal” for better visual hierarchy
Best Practices for Working with AI-Generated Use Case Diagrams
  • Review scope at a glance — Does the diagram show only what’s inside the boundary? Are any out-of-scope use cases accidentally included?
  • Check actor coverage — Every primary actor from Section 1.3 should appear if they have meaningful goals.
  • Validate naming consistency — Ensure use case names remain goal-oriented and verb-first.
  • Use for early validation — Share the diagram (export as image or link) with stakeholders: “Does this picture capture what the system should do?”
  • Iterate quickly — If feedback reveals gaps (e.g., “We need waitlist handling”), add the use case to the table—the diagram regenerates automatically.
  • Prepare for refinement — This initial diagram is intentionally high-level; include/extend relationships and detailed flows come in Module 3.
By the end of Section 2.3, you have your first major visual deliverable: a clean, professional Use Case Diagram that communicates system functionality clearly and concisely. This artifact becomes the shared reference point for refinement, detailed specification, and alignment across the entire project team—proving that great modeling starts with seeing the big picture fast.
