1. ホーム
  2. ドキュメント
  4. Preface
Preface
In an era where AI-powered tools like Visual Paradigm’s Use Case Modeling Studio can generate detailed use case specifications, UML diagrams (including Use Case, Activity, Sequence, and Class Diagrams), test cases, and even polished Software Design Documents (SDDs) from simple text prompts in seconds, it’s natural to wonder: Why bother learning the fundamentals of use case-driven development? Why invest time in a course when AI appears to handle everything automatically?
The short answer is that AI is an exceptionally powerful assistant, but it is not a replacement for human judgment, domain expertise, or critical thinking. Tools like the AI Modeling Studio excel at accelerating routine tasks—such as drafting initial use case flows, suggesting actors, identifying shared functionality for «include» relationships, spotting optional behaviors for «extend» relationships, or converting textual descriptions into visual workflows—but they rely entirely on the quality and clarity of the input you provide. More importantly, AI lacks true understanding of business context, stakeholder nuances, ethical implications, or subtle trade-offs that define real-world software success.
Why We Still Need to Master the Concepts
Learning the core principles of use case modeling—actors, goals, flows (main, alternative, exception), preconditions/postconditions, relationships («include» for mandatory reuse, «extend» for optional/variant behavior), scenario analysis, and traceability to requirements—equips you to:
  • Provide high-quality prompts that guide the AI toward accurate, relevant outputs instead of generic or incomplete ones. For example, a vague prompt like “build an ATM system” might yield a basic set of use cases, but a well-informed user who understands stakeholder analysis can refine the prompt to include specific constraints (e.g., security regulations, multi-channel access for mobile banking), leading to far more precise diagrams and specifications.
  • Validate and refine AI-generated artifacts. AI can occasionally hallucinate incorrect relationships, miss edge cases, or apply patterns inappropriately. Human oversight ensures the models align with actual business needs. Consider a banking system: The AI might suggest an «include» relationship for “Authenticate User” across multiple use cases, which is often correct. But if domain rules dictate that authentication should be conditional in certain flows (e.g., for low-risk queries), you—as the knowledgeable user—must spot and correct this to avoid flawed design or security gaps.
  • Make strategic decisions that AI cannot. The tool identifies patterns like shared sub-flows (for «include») or conditional extensions (for «extend») based on common UML best practices, but it doesn’t know your project’s unique priorities, such as performance constraints, regulatory compliance, or scalability needs. You decide whether to accept, modify, or reject its suggestions.
  • Act as an effective co-pilot. Think of the AI as a junior team member who’s fast but needs direction and review. You steer the process: iterating on refinements, cross-checking against requirements traceability (e.g., via the Project Dashboard), or ensuring test case coverage matches real risks.
Practical Examples
  • Example 1: Incomplete AI output — For a dining reservation system, the AI generates a Use Case Diagram with basic actors (Customer, Manager) and use cases (Book Table, Cancel Reservation). Without your understanding of reservation workflows, you might miss that “Handle Waitlist” should be an «extend» on “Book Table” (only when fully booked), preventing overbooking issues. You spot and refine this.
  • Example 2: Over-generalization — The AI auto-generates Activity Diagrams from flows, but it may flatten complex decision logic. You validate by mapping scenarios to decision tables, ensuring all unique combinations (e.g., payment failure + insufficient funds) are covered—critical for robust exception handling.
  • Example 3: Test case validation — AI can produce test cases with steps and expected results, but you review them against non-functional requirements (e.g., performance under load) or edge conditions it overlooked, guaranteeing comprehensive quality assurance.
Ultimately, this course isn’t about competing with AI—it’s about partnering with it effectively. By mastering the methodology, you transform from a passive user of AI outputs into an active architect who leverages the tool to deliver higher-quality, more maintainable systems faster. The AI handles the drudgery; you bring the insight, creativity, and accountability that turn good models into great software.
Welcome to the course—let’s build smarter systems together.
