1. ホーム
  2. ドキュメント
  3. Streamlining the Software...
  4. 3. Use Case Refinement an...
  5. 3.2 Automated Refinement
Using the AI Use Case Diagram Refinement Tool to Transform Basic Overviews into Professional-Grade Architectural Diagrams
Once shared functionality has been factored out with «include» relationships and optional/conditional behavior has been captured with «extend» arrows (as identified in Section 3.1), the Use Case Diagram is already much cleaner and more expressive. However, it may still look like a rough draft: inconsistent naming, suboptimal layout, crowded clusters of use cases, missing extension points, or minor stylistic inconsistencies.
This is exactly where the AI Use Case Diagram Refinement Tool in Visual Paradigm’s Modeling Studio becomes a game-changer.
Rather than manually dragging elements, renaming ovals, adjusting arrow directions, adding extension points, or reorganizing for readability, you simply invoke the refinement tool (often labeled “Refine Diagram”, “Auto-Improve”, or “Professional Refinement”). The AI then performs a multi-pass analysis and transformation:
  • Renames use cases for consistency, clarity, and UML naming conventions (verb + noun, present tense, actor-goal focus)
  • Adds or clarifies extension points on base use cases when «extend» relationships are present
  • Reorganizes layout for optimal readability (minimizes crossing lines, balances left/right actor placement, groups related use cases)
  • Applies professional visual styling (consistent font sizes, proper arrowhead placement, subtle color differentiation if configured)
  • Detects and suggests minor structural improvements (e.g., splitting an overly broad use case, merging near-identical ones, adding boundary packages for sub-systems)
  • Ensures traceability by keeping all changes synchronized with the underlying use case table
After refinement, the tool presents a before/after comparison or highlights changes for review. You can accept the entire proposal, selectively revert individual suggestions, or manually tweak the result. The outcome is a professional-grade architectural diagram that looks like the work of an experienced modeler—ready for stakeholder presentations, design handoff, or inclusion in formal documentation.
Practical Examples
Example 1: GourmetReserve – Mobile Dining Reservation App
Before Refinement (after 3.1):
  • “Book a Table” had two incoming «extend» arrows (Apply Discount Coupon, Handle Waitlist) but no labeled extension points
  • “Authenticate User” was placed randomly with crossing «include» lines
  • Use case names were inconsistent (“Receive Booking Reminder” vs. “Send Reminder”)
  • Diagram felt crowded near the Diner actor
AI Refinement Actions:
  • Renames → “Receive Booking Reminder” → “Receive Reservation Reminder” for consistency
  • Adds extension points on “Book a Table” oval:
    • «extension point» Enter promo code → Apply Discount Coupon
    • «extension point» No tables available → Handle Waitlist
  • Re-positions “Authenticate User” centrally with straight, non-crossing «include» arrows from Book a Table, Pre-order Meal, Cancel Reservation, Manage Reservations
  • Groups Diner-related use cases on the left, Restaurant Staff on the right, external systems at the bottom
  • Applies subtle shading to the system boundary and consistent oval sizing
After Result:
  • Diagram looks polished and publication-ready
  • Extension points are clearly labeled inside the base use case oval
  • No crossing lines, excellent visual balance
  • Stakeholders immediately understand the mandatory core flow vs. optional enhancements
Example 2: SecureATM – Next-Generation ATM Network
Before Refinement:
  • Many «include» arrows converging on “Authenticate User” created a visual “spider web”
  • “Request Biometric Verification” extended “Withdraw Cash” but extension point was missing
  • Some use case names were too long or inconsistent (“Monitor ATM Status & Alerts” vs. “Check ATM Status”)
  • Shortens and standardizes → “Monitor ATM Status & Alerts” → “Monitor ATM Status”
  • Adds extension point on “Withdraw Cash” oval: «extension point» Amount exceeds threshold → Request Biometric Verification
  • Rearranges layout: places Retail Customer on left, Bank Operations Team on right, Fraud Detection System at bottom
  • Uses a slight radial layout around “Authenticate User” to untangle incoming «include» arrows
  • Suggests and applies a light color differentiation: customer use cases in one shade, operations in another
After Result:
  • Clean, hierarchical appearance with clear separation of concerns
  • Authentication clearly shown as foundational infrastructure
  • High-value transaction security path is visually traceable via the extension point and dashed «extend» arrow
Example 3: CorpLearn – Corporate E-Learning Platform
Before Refinement:
  • “Record Learning Progress” had incoming «include» arrows from multiple use cases but looked buried
  • Extension point for “Issue Certificate” was implied but not labeled
  • Diagram had uneven spacing; Manager and Compliance Officer actors were placed awkwardly
  • Adds explicit extension point on “Take Final Assessment” oval: «extension point» Passing score achieved → Issue Certificate
  • Places “Authenticate via SSO” centrally and routes all «include» arrows neatly
  • Groups learner-facing use cases in a logical vertical stack on the left
  • Positions administrative actors (HR Admin, Manager, Compliance Officer) on the right with horizontal alignment
  • Suggests a small package boundary labeled “Learner Portal” around employee use cases for better visual hierarchy (optional—accepted in this case)
After Result:
  • Diagram communicates clear separation between learner self-service and administrative control
  • Progress tracking and authentication are visibly shared infrastructure
  • Extension point makes it obvious that certification is conditional rather than automatic
Best Practices When Using the Refinement Tool
  • Run refinement after accepting the main «include»/«extend» suggestions from 3.1 — it works best on a relationship-rich diagram.
  • Always review the change log or before/after view — AI may occasionally over-generalize a name or misplace an element.
  • Use the refined diagram for stakeholder walkthroughs — its professional appearance builds confidence and invites better feedback.
  • Save versions — you can always revert to the pre-refinement state if a particular layout suggestion doesn’t fit your project style.
  • Combine with manual polish — the AI gets you 90% there; a few final drags or label adjustments make it 100%.
By the end of Section 3.2, your Use Case Diagram has evolved from a useful but rough sketch into a professional-grade architectural view — one that is clear, consistent, visually appealing, and structurally sound. This polished model serves as the perfect foundation for writing detailed use case specifications (Module 4), generating behavioral diagrams, and producing high-coverage test cases. The AI has handled the tedious layout and pattern work; your domain expertise ensures the final diagram accurately reflects business reality.
