1. ホーム
  2. ドキュメント
  3. Streamlining the Software...
  4. 5. Behavioral and Structu...
  5. 5.1 Behavior Modeling (Activity Diagrams)
Transforming Textual Requirements into Visual Workflows to Ensure Clear System Logic
While use case specifications provide a precise, step-by-step textual description of system behavior, they remain linear and can become difficult to follow when flows include decisions, parallelism, loops, or complex exception handling. Activity Diagrams address this limitation by turning those textual flows into intuitive, visual workflows that clearly show:
  • The sequence of actions
  • Decision points and branching paths
  • Parallel (concurrent) execution
  • Loops and iteration
  • Swimlanes (partitions) that assign responsibility to actors, the system, or external services
  • Start/end nodes, merge/fork/join nodes, and exception handling paths
These diagrams are especially valuable for developers implementing logic, testers designing coverage, and stakeholders validating that the intended process is realistic and complete.
In Visual Paradigm’s AI-Powered Use Case Modeling Studio, you generate an Activity Diagram directly from a selected use case specification (or from a group of related use cases) by clicking “Generate Activity Diagram” or “Visualize Flow”. The AI analyzes:
  • The Main Success Scenario steps
  • Alternative and Exception Flows
  • Preconditions/postconditions
  • Any «include» sub-flows (treated as call behavior actions or sub-activities)
  • Extension points and their conditional triggers
It then produces an initial diagram with:
  • Swimlanes for primary actor, system, and key secondary actors
  • Action nodes derived from step verbs
  • Decision nodes for branches (e.g., “Tables available?”)
  • Fork/join for parallelism (e.g., sending confirmation + scheduling reminder)
  • Exception paths routed to appropriate recovery actions or end states
You refine the diagram by adding guards on transitions, renaming nodes for clarity, adjusting layout, inserting interruptible regions for timeouts/cancellations, or grouping repeated logic into sub-activities.
Practical Examples
Example 1: GourmetReserve – Use Case: Book a Table
AI-Generated Activity Diagram Highlights:
  • Swimlanes: Diner | Mobile App / Reservation Service | Payment Gateway | Notification Service
  • Flow:
    • Start → [Diner] Search available tables → [System] Display results
    • Decision: “Tables available for requested time & size?”
      • Yes → [Diner] Select slot & party details → [System] Include Process Payment sub-activity
      • No → [System] Offer alternative times OR [Diner] Join waitlist (parallel paths via fork)
    • After payment → [Diner] Confirm booking → [System] Create reservation
    • Fork → [Notification Service] Send immediate confirmation AND Schedule 24h reminder
    • Join → End (reservation confirmed)
  • Exception path (from payment):
    • Decision: “Payment successful?”
      • No → Display error → Loop back to retry (max 3 attempts) OR Cancel → End (reservation aborted)
Typical refinement you add:
  • Guard on payment retry loop: “[attempts < 3]”
  • Interruptible region around confirmation step with “Cancel Booking” trigger leading to refund process
Example 2: SecureATM – Use Case: Withdraw Cash
AI-Generated Diagram Structure:
  • Swimlanes: Customer | ATM Interface | Core Banking Service | Cash Dispenser
  • Main flow:
    • Start → [Customer] Select Withdraw Cash
    • Include Authenticate User sub-activity
    • [Customer] Enter amount
    • Decision: “Amount within daily limit AND sufficient funds?”
      • Yes → [Banking Service] Debit account → [Cash Dispenser] Dispense cash
      • No → [ATM Interface] Display appropriate error (limit / funds) → Return to enter amount OR End
    • Decision: “Print receipt?”
      • Yes → Parallel fork → Print receipt (concurrent with dispense)
    • Join → Update transaction log → End
  • Exception paths:
    • If cash cassette low → Interrupt flow → Display “Temporarily unavailable” → Alert operations → End
Refinement example:
  • Add timer event on “Enter amount” (30-second timeout → eject card and end transaction)
Example 3: CorpLearn – Use Case: Take Final Assessment
AI-Generated Flow:
  • Swimlanes: Learner | Web/Mobile App | Assessment Engine | Certificate Service
  • Flow:
    • Start → [Learner] Start Final Assessment
    • [System] Present questions (timed)
    • Loop: While questions remain AND time > 0 → [Learner] Answer question → [System] Record answer
    • Time expires OR all answered → [System] Auto-submit
    • [Assessment Engine] Evaluate answers → Calculate score
    • Decision: “Score ≥ 80% AND all compliance acknowledgments completed?”
      • Yes → Fork → [Certificate Service] Generate & email certificate | [System] Record completion & progress
      • No → Display results → Decision: “Retakes allowed AND attempts < 2?”
        • Yes → Return to enrollment for retake scheduling
        • No → Mark course as failed → End
    • Join → End
Common refinement:
  • Add data store node “Learner Progress” updated after every section (for partial saves)
  • Insert compliance acknowledgment as a mandatory sub-activity before the final decision
Best Practices for Activity Diagram Generation & Refinement
  • Use swimlanes consistently — Clearly separate actor, system front-end, back-end services, and external actors.
  • Leverage guards — Add precise conditions on decision branches (e.g., “[amount ≤ remaining balance – fee]”).
  • Show parallelism — Use fork/join for concurrent actions (e.g., send email + update database).
  • Handle interruptions — Model timeouts, cancellations, or system failures with event-triggered transitions.
  • Keep sub-activities modular — Reuse common flows (e.g., “Authenticate User”, “Process Payment”) as call behavior actions.
  • Validate completeness — Walk through every alternative and exception flow from the use case spec to ensure no paths are missing.
By the end of Section 5.1, you will have clear, visual representations of system workflows that eliminate ambiguity in complex logic. These Activity Diagrams serve as the direct input for code-level implementation decisions, unit/integration test design, and user training materials. The AI removes the tedium of drawing nodes and arrows — your expertise ensures the workflow accurately mirrors real business rules and edge cases. With behavior visualized, you’re ready to explore the dynamic interactions between components in Sequence Diagrams (next section).
