1. Inicio
  2. Documentos
  4. Module 4: The Heartbeat –...
  5. Timing Diagrams
Timing Diagrams
Focusing on time constraints and state changes over a specific timeline.
Inspection UML timing diagram example
Timing diagrams in UML 2.5 are specialized behavioral diagrams designed to model precise temporal aspects of system behavior—particularly state changes, value changes, or condition durations over a continuous or discrete timeline. Unlike sequence diagrams (which show discrete message ordering) or state machines (which focus on event-triggered transitions), timing diagrams emphasize time as the primary axis: how long states persist, when transitions must occur, deadlines, periods, jitter, response times, and timing constraints.
Key elements of timing diagrams:
  • Lifeline — Horizontal line for each participant (object, role, component, system, or signal).
  • Timeline — Horizontal axis representing time (continuous or discrete ticks).
  • State/Condition Timeline — Thick line segment showing duration of a state or value (e.g., solid for “Heating”, dashed for “Idle”).
  • Transition — Vertical line or slanted arrow between state changes, labeled with event or trigger.
  • Time Constraint — {duration} notation (e.g., {t ≤ 50ms}, {response < 200ms}, {period = 1s ± 10ms}).
  • Duration Constraint — Between two points on timeline, e.g., {d} or {min..max}.
  • Time Mark — Vertical dashed line labeled t0, t1, etc., for reference points.
  • Value Change — Can show variable values over time (e.g., temperature rising from 20°C to 25°C).
  • Compact vs. Robust notation — Compact (state line with changes) or robust (explicit state regions).
Timing diagrams are especially valuable in:
  • Real-time and embedded systems
  • Performance-critical applications
  • Protocols with strict timing
  • Hardware-software co-design
  • Systems with QoS requirements (latency, throughput, jitter)
  • Validating SLAs or regulatory timing rules
In Agile & use-case-driven projects, they are used sparingly but powerfully—typically for high-risk timing aspects identified during use case elaboration or architectural spikes.
Practical Examples of Timing Diagrams in Real Projects
Here are numerous concrete examples showing timing diagrams modeling time-sensitive behavior:
  • E-commerce – Payment Gateway Response Time SLA
    • Lifelines: :CustomerApp, :PaymentService, :ExternalGateway Timeline: t0 = payment request sent
    • CustomerApp: Processing (t0 to t0+500ms)
    • PaymentService: Authorizing (t0 to t0+200ms) → WaitingForGateway (t0+200ms to t0+800ms)
    • ExternalGateway: Idle → Processing (t0+300ms to t0+700ms) → Approved Constraints: {response time ≤ 1000ms} from t0 to approval {gateway latency ≤ 500ms} Practical benefit: Visualizes end-to-end latency budget; used to set timeouts and retry policies.
  • Mobile Banking – Transaction Authorization Timeout
    • Lifelines: :MobileApp, :AuthService, :CoreBanking Timeline: t0 = transfer initiated
    • MobileApp: AwaitingOTP (t0 to t0+120s)
    • AuthService: OTPGenerated → OTPValid (t0 to t0+300s)
    • CoreBanking: Pending → Executed (only if OTP validated within 60s) Constraint: {OTP validity = 120s} Transition at t0+60s: [no OTP entered] → Timeout / cancelTransaction() Practical: Ensures security window is enforced; helps test timeout edge cases.
  • Ride-Sharing – ETA Calculation & Real-Time Updates
    • Lifelines: :DriverApp, :MatchingService, :RiderApp Timeline: t0 = ride accepted
    • DriverApp: EnRoute (t0 → t_end) with periodic location updates every 5s ± 1s
    • MatchingService: CalculatingETA (t0 to t0+2s) → StableETA (t0+2s onward)
    • RiderApp: ShowingETA (updates every 10s) Constraint: {ETA refresh ≤ 10s} {jitter ≤ 2s} Practical: Exposes acceptable delay for user experience; guides WebSocket heartbeat frequency.
  • Healthcare – Defibrillator Response in Cardiac Arrest
    • Lifelines: :MonitorDevice, :Defibrillator, :Patient Timeline: t0 = arrhythmia detected
    • MonitorDevice: Monitoring → ShockAdvisory (t0 to t0+5s)
    • Defibrillator: Standby → Charging (t0+5s to t0+8s) → ReadyToShock
    • Patient: Fibrillating → NormalRhythm (after shock at t0+10s ± 2s) Constraint: {time to shock ≤ 10s} {charge time ≤ 3s} Practical: Critical for device certification (IEC 60601); used in safety analysis.
  • IoT Smart Thermostat – Temperature Control Loop
    • Lifelines: :ThermostatController, :TemperatureSensor, :Heater Timeline: t = continuous
    • TemperatureSensor: Reading (oscillating 19–21°C)
    • ThermostatController: Idle → Heating (when temp < 20°C – 0.5°C hysteresis)
    • Heater: Off → On (duration until temp ≥ 21°C) Constraint: {overshoot ≤ 1°C} {settling time ≤ 5min} {cycle period ≈ 10min} Practical: Models PID-like control loop timing; validates energy efficiency claims.
  • Real-Time Stock Trading – Order Matching Latency
    • Lifelines: :TraderGateway, :MatchingEngine, :MarketDataPublisher Timeline: t0 = order arrives
    • TraderGateway: Received → Forwarded (t0 to t0+2ms)
    • MatchingEngine: Queued → Matching (t0+2ms to t0+5ms) → Executed
    • MarketDataPublisher: UpdateSent (within t0+10ms) Constraint: {end-to-end matching ≤ 5ms} {market data update ≤ 10ms} Practical: Regulatory requirement visualization; used in performance budgeting.
  • Automotive – Adaptive Cruise Control Reaction
    • Lifelines: :RadarSensor, :ACCController, :ThrottleActuator, :BrakeActuator Timeline: t0 = lead vehicle slows
    • RadarSensor: Detecting → RangeDecreasing
    • ACCController: Maintaining → Decelerating (t0+50ms)
    • ThrottleActuator: Open → Closing (t0+100ms)
    • BrakeActuator: Inactive → LightBraking (t0+200ms if needed) Constraint: {reaction time ≤ 200ms} {deceleration ramp ≤ 3m/s²} Practical: ISO 26262 safety timing analysis; shows coordinated actuator response.
  • Embedded Device – Watchdog Timer Reset
    • Lifelines: :Application, :WatchdogTimer Timeline: t = continuous
    • Application: Running → Stalled (if no kick within 500ms)
    • WatchdogTimer: Armed → Timeout (after 500ms) → ResetSystem Constraint: {kick interval ≤ 400ms} {tolerance ±50ms} Practical: Ensures system recovery from hangs; critical for reliability in field devices.
In Visual Paradigm:
  • Create horizontal lifelines and drag state/condition segments.
  • Add time constraints with curly braces {…}.
  • Use compact mode for simple state changes or robust for detailed durations.
  • Annotate with time marks (t0, t1) and duration markers.
  • Simulate timing to verify constraints.
  • Semantic backplane links timing constraints to state machines, sequence messages, or requirements.
Timing diagrams are the precision instrument for time-critical behavior—making deadlines, latencies, periods, and jitter explicit and verifiable. They complete the set of 7 behavioral diagrams, equipping you to model both high-level orchestration and microsecond-level timing constraints.
With the heartbeat of behavior fully covered, you’re ready for Module 5: Agile Architecture and Implementation Workflows, where we connect everything to code, patterns, and iterative delivery.
