1. Accueil
  2. Docs
  4. 7. Quality Assurance and Testing
After investing significant effort in defining a clear vision, detailed requirements, refined models, validated logic, and a complete design blueprint, the natural next question is:
“How do we know — with confidence — that what we built actually matches what we intended, behaves correctly under all relevant conditions, and delivers the expected value without critical defects?”
This is the core purpose of Quality Assurance and Testing in a use case-driven approach. Module 7 shifts the focus from design and specification to verification and validation: systematically confirming that the implemented system fulfills the documented requirements, handles edge cases gracefully, meets non-functional expectations, and remains free of logical, functional, or usability defects.
In traditional projects, testing often begins late — after coding — and suffers from incomplete coverage, ambiguous test cases, and poor traceability. Visual Paradigm’s AI-Powered Use Case Modeling Studio integrates quality assurance tightly into the workflow, turning artifacts produced in earlier modules into high-quality, traceable test assets almost automatically.
This module emphasizes two key deliverables:
  1. Automated Test Case Creation The AI generates a comprehensive set of test cases directly from use case specifications, decision tables, Activity Diagrams, and Sequence Diagrams. Each test case includes:
    • Test ID
    • Scenario / Objective
    • Preconditions
    • Test Steps
    • Expected Result
    • Priority / Risk level
    • Traceability link back to the originating use case step, decision rule, or diagram element
  2. Requirements Validation & Coverage Tracking Using the Project Dashboard, you monitor completeness and test coverage across:
    • Use cases (are all major flows tested?)
    • Decision tables (is every rule covered by at least one test?)
    • Scenarios (happy path, alternatives, exceptions, boundary cases)
    • Non-functional aspects (if captured in notes or constraints)
The result is a living, traceable test suite that evolves with the requirements — not a disconnected spreadsheet created months later. This tight integration dramatically reduces the risk of defects slipping through and provides strong evidence of due diligence for stakeholders, auditors, or compliance reviews.
Why This Step Is Non-Negotiable (Even with Strong Models)
No matter how elegant the Class Diagram, how clean the Sequence Diagram, or how exhaustive the decision tables, assumptions can still be wrong:
  • A business rule was misinterpreted
  • An edge case was overlooked
  • Concurrent or performance issues emerge only in real execution
  • Usability or accessibility needs were not surfaced earlier
Systematic testing — rooted in the use case model — is the final reality check. It turns “I think this works” into “We have proven this works under defined conditions.”
Practical Examples of AI-Generated Test Assets
Example 1: GourmetReserve – Use Case: Book a Table
AI-Generated Test Cases (excerpt):
  • TC-001 – Happy Path – No Deposit Required Priority: High Preconditions: Diner logged in (Gold loyalty), tables available, non-peak hours, party size 4 Steps:
    1. Search tables → select slot
    2. Review summary (no deposit shown)
    3. Confirm booking Expected: Reservation confirmed, confirmation sent, no payment screen Trace: Main flow steps 1–7, Decision Table Rule R1
  • TC-002 – Deposit Required – Payment Fails Priority: High Preconditions: Party size 10, peak hours, non-Gold, valid card but insufficient funds Steps:
    1. Select slot → proceed to payment
    2. Enter card → submit Expected: Error message “Payment declined”, booking not created, return to slot selection Trace: Decision Table Rule R5, Exception flow 4b
Example 2: SecureATM – Withdraw Cash
  • TC-ATM-003 – High-Value Transaction – Biometric Fail Priority: Critical Preconditions: Authenticated, sufficient funds & limit, amount $1,500, biometric supported Steps:
    1. Enter $1,500
    2. Prompt for biometric → fail scan Expected: Transaction aborted, card retained, message “Security verification failed – contact support”, fraud alert sent Trace: Decision Table Rule 3
Example 3: CorpLearn – Take Final Assessment
  • TC-LRN-004 – Privacy Question Failed Priority: High (compliance) Preconditions: All modules complete, time remaining, acknowledgments done Steps:
    1. Answer questions → intentionally wrong on mandatory privacy question
    2. Submit assessment Expected: Score ignored → auto-fail message “Data privacy acknowledgment failed”, no certificate, record logged for audit Trace: Decision Table Rule 2
Key Outcomes of Module 7
By the end of this module, you will have:
  • A traceable, AI-assisted test suite covering functional flows, alternatives, exceptions, and decision rules
  • Quantitative coverage metrics visible in the Project Dashboard (e.g., “92% of decision table rules tested”)
  • Clear risk-based prioritization of remaining test cases
  • Strong confidence that the system meets its intended purpose — and evidence to prove it
This phase closes the loop: from initial vision → detailed models → validated logic → proven implementation readiness. With quality assurance complete, the project is positioned not just to build software, but to deliver reliable, valuable, and maintainable solutions that stakeholders can trust.
Articles
