1. ホーム
  2. ドキュメント
  4. Module 5: Modeling Behavi...
  5. Diagram Touch-Up” Technology
Refining Interactions Iteratively—Such as Adding Two-Factor Authentication—While Maintaining Layout Integrity
One of the most frustrating aspects of traditional Sequence Diagram editing is the cascade effect of even small changes. Add a new message, insert a combined fragment, or reorder lifelines—and suddenly arrows cross, activation bars misalign, fragments resize awkwardly, labels overlap, and the entire diagram requires minutes (or hours) of manual cleanup to restore readability. This mechanical overhead discourages iteration, experimentation, and refinement, often leaving diagrams frozen in their first rough form.
Visual Paradigm’s Diagram Touch-Up technology fundamentally solves this problem. It is the intelligent engine that powers safe, incremental, conversational refinement across all AI-generated diagrams—especially powerful in behavioral modeling where complexity grows quickly. Unlike flat image generators or text-to-code tools that force full regeneration on every change (breaking layout, losing context, and discarding previous refinements), Diagram Touch-Up treats the diagram as a living, model-aware structure. Every update is applied surgically: semantics are preserved, layout logic is respected, and visual integrity is maintained automatically.
How Diagram Touch-Up Enables Frictionless Iteration
  1. The Starting Point You already have a generated Sequence Diagram (e.g., a basic login flow) from a prior prompt.
  2. Issue a Natural-Language Refinement Command Common examples that trigger Touch-Up:
    • “Add two-factor authentication: after password check, send OTP via SMS Gateway and validate before granting access.”
    • “Insert an opt fragment for ‘Remember Me’ cookie creation after successful login.”
    • “Add a timeout of 60 seconds around the entire authentication process.”
    • “Show parallel execution: while validating credentials, also log the attempt to Audit Service.”
    • “Change the failure path to include a retry loop (max 3 attempts) before locking the account.”
    • “Move the SMS Gateway lifeline to the far right and make the OTP message dashed (asynchronous).”
  3. What Happens Under the Hood Diagram Touch-Up performs a multi-step intelligent update:
    • Semantic understanding — Parses the command to identify which lifeline(s), message(s), fragment(s), or constraint(s) are affected.
    • Model consistency — Ensures the change respects existing structure (e.g., doesn’t violate loop nesting, fragment boundaries, or message ordering).
    • Incremental insertion — Adds new elements (messages, fragments, notes) at the logically correct vertical position without overwriting unrelated content.
    • Layout preservation & intelligent adjustment:
      • Reroutes crossing or overlapping arrows using smart routing algorithms.
      • Adjusts activation bar lengths automatically.
      • Expands/shrinks combined fragments (alt, loop, par, etc.) only as needed.
      • Rebalances spacing between lifelines and messages for readability.
      • Maintains consistent visual style (arrow types, label placement, font sizes).
    • No full redraw — Only affected regions are recalculated; the rest of the diagram remains untouched.
  4. Result: Immediate, Polished Update The diagram refreshes in place—clean, readable, and semantically correct—ready for the next refinement or review. Multiple changes can be stacked in rapid succession without accumulating layout debt.
Comparison: Old Way vs. Diagram Touch-Up
Aspect Traditional Manual / Regenerating Tools Diagram Touch-Up Technology
Effect of adding one message/fragment Often requires repositioning 10+ elements Automatic rerouting and spacing—zero manual fixes
Cumulative refinement cost Increases exponentially; discourages iteration Near-zero cost; encourages experimentation
Risk of losing previous work High (full redraw overwrites context) None—preserves all prior details
Time to refine complex scenario Minutes to hours per change Seconds per command
Readability after 5–10 changes Usually degraded (crossed lines, cramped labels) Consistently professional and clear
Support for “what-if” exploration Painful and slow Fast, safe, and inviting
Real-World Examples of Touch-Up in Action
  • Adding 2FA mid-flow Original diagram: simple username/password login. Command: “Insert two-factor authentication after password validation.” Touch-Up result: New lifeline for SMS Gateway appears, opt/alt fragment wraps OTP step, messages route cleanly, activation bars extend appropriately—no manual dragging.
  • Introducing parallelism Command: “After payment success, send confirmation email and notify warehouse in parallel.” Touch-Up: Adds par fragment, splits flow, inserts two async messages, rejoins at merge point, adjusts vertical spacing intelligently.
  • Handling timeouts & retries Command: “Wrap payment call in a timeout of 45 seconds and allow 2 retries on failure.” Touch-Up: Inserts critical fragment with timeout constraint, nests loop + alt for retry logic, reroutes return paths, keeps diagram balanced.
Why This Matters for Behavioral Modeling
Diagram Touch-Up turns Sequence Diagrams from static artifacts into dynamic design conversations. You can:
  • Explore alternative flows without fear
  • Respond instantly to stakeholder feedback (“What if we add SSO?”)
  • Prototype complex error handling and edge cases
  • Maintain high visual quality throughout dozens of iterations
  • Focus entirely on interaction semantics, timing, responsibilities, and architectural alignment—not on fighting the tool
This technology is what makes behavioral modeling truly agile: fast enough for early design sprints, precise enough for detailed specifications, and flexible enough to evolve as understanding deepens.
With safe, intelligent refinement now at your fingertips, the next sections build on this power—mapping use-case flows to layered sequences, deriving detailed message signatures, and transitioning to State Machine modeling for lifecycle behavior. The AI no longer just draws diagrams; it collaborates with you to evolve them gracefully.
