1. ホーム
  2. ドキュメント
  4. Module 5: Agile Architect...
  5. Agile Code Engineering
Forward Engineering: Transforming UML models into executable code. ◦
Reverse Engineering: Reconstructing models from existing implementations to aid understanding. ◦
Round-Trip Engineering: Maintaining consistency between graphical models and textual code.
In Agile environments, code engineering workflows turn UML models from passive documentation into active, living assets that directly support rapid, iterative delivery. Visual Paradigm (and similar tools) provides seamless integration between graphical modeling and source code through three complementary techniques:
  • Forward Engineering — Generate code skeletons, classes, interfaces, methods, and even full implementations from UML elements (classes, components, operations, state machines, etc.). This accelerates initial development and enforces architectural decisions early.
  • Reverse Engineering — Import existing source code (Java, C#, Python, C++, etc.) to automatically reconstruct UML diagrams (class, sequence, package, component). Ideal for onboarding, legacy understanding, or auditing.
  • Round-Trip Engineering — Bidirectional synchronization: changes in the model update code, and changes in code update the model—keeping both views consistent without manual double-entry.
These workflows align perfectly with Agile principles: start lightweight, generate just enough code to test hypotheses, refactor safely, and evolve models/code together in short feedback loops.
Practical Examples Across Real Projects
  • E-commerce Platform – Forward Engineering New Microservice
    • Model: Class diagram + component diagram for “DiscountService” (classes: DiscountRule, PercentageDiscount, FixedAmountDiscount; operations: applyDiscount(order)).
    • Forward: Generate Spring Boot service class, DTOs, repository interface, controller stubs in Java.
    • Result: Developer starts with 80% boilerplate done → focuses on business logic (discount rules).
    • Later sprint: Add new rule type in model → forward again → only new concrete class generated. Benefit: Consistent structure across services; reduces setup time from hours to minutes.
  • Mobile Banking App – Reverse Engineering Legacy Authentication Module
    • Existing code: Old monolithic Java JAR with authentication logic scattered across 15 classes.
    • Reverse: Import JAR → Visual Paradigm reconstructs class diagram, package structure, sequence diagrams for login flow.
    • Outcome: New team quickly sees legacy coupling → identifies extractable AuthService component.
    • Follow-up: Annotate reverse-engineered diagram with «legacy» stereotype → plan strangler refactoring.
  • Task Management SaaS – Round-Trip for Real-Time Collaboration Feature
    • Initial model: Collaboration «WebSocketSync» + sequence diagram → forward generate Node.js classes (Card, BoardEventPublisher, SubscriberManager).
    • Developer adds retry logic + exponential backoff in code (not yet in model).
    • Round-trip sync: Import updated .js files → model auto-updates with new methods and sequence fragments.
    • Team reviews updated sequence → adds guard conditions and timeout states → forward generates test stubs. Benefit: Model stays accurate documentation; refactoring never loses synchronization.
  • Healthcare Telemedicine – Forward from State Machine
    • Model: State machine for “ConsultationSession” (states: Scheduled, InProgress, Paused, Completed, Cancelled; transitions with guards and actions).
    • Forward: Generate Java enum for states, state pattern classes (ConsultationState interface + concrete states), transition handler methods.
    • Result: Robust, maintainable state logic → developer only implements domain-specific actions (e.g., notifyParticipants()).
    • Later: Add “Recording” orthogonal region → forward adds new composite state behavior.
  • Legacy ERP Modernization – Reverse + Round-Trip Hybrid
    • Phase 1: Reverse engineer COBOL/JCL → UML class + package diagrams of “Billing” module.
    • Phase 2: Create new microservice model (Java/Spring) → forward generate skeleton.
    • Phase 3: Implement adapter pattern → code changes synced back to model.
    • Ongoing: Every sprint, reverse delta from legacy → compare with new model → track strangler progress visually.
  • IoT Smart Home – Forward + Round-Trip for Firmware Update Service
    • Model: Component diagram + sequence for OTA handshake → forward generate Python FastAPI endpoints, request/response models.
    • Embedded team modifies checksum validation in C firmware → reverse C code snippets → update sequence diagram.
    • Round-trip: Model now reflects both cloud and device-side behavior → next forward adds validation logging.
  • Financial Trading Platform – Round-Trip for Risk Check Operation
    • Complex operation: preTradeRiskCheck()
    • Model: Collaboration realizing the operation → forward generates method signature + delegate calls to risk engines.
    • Quant team adds new limit check in code → round-trip → model shows new sequence step.
    • Architect reviews → adds guard [positionLimitOk] → forward updates conditional logic in code.
  • Restaurant POS System – Forward from Activity Diagram
    • Activity diagram for “Process Order Payment” (swimlanes: POS, PaymentTerminal, Backend).
    • Forward: Generate method stubs in POS client (C#) and backend service (Java) with matching flow.
    • Benefit: UI and backend stay aligned on workflow → reduces integration bugs.
In Visual Paradigm (hands-on highlights):
  • Forward: Right-click class/component → Generate Code → Choose language/template (Java Spring, .NET, Python Flask, etc.) → Customize generation rules.
  • Reverse: Project → Reverse Engineering → Import source folder/JAR → Select diagrams to generate (class, sequence from method calls, etc.).
  • Round-Trip: Enable synchronization → Edit code in IDE → Update model (or vice versa) → Diff viewer shows changes → Accept/Reject selectively.
  • Use code synchronization profiles to control visibility, naming conventions, and ignored elements.
  • Generate code from state machines (state pattern) or activity diagrams (structured code blocks).
Summary of Agile Benefits
  • Speed: Forward engineering cuts boilerplate and scaffolding time dramatically.
  • Understanding: Reverse engineering turns opaque legacy into explorable visual maps.
  • Consistency: Round-trip prevents model-code drift—models remain trustworthy documentation.
  • Refactoring Safety: Change model → propagate to code; change code → reflect in model.
  • Traceability: Links from use cases → collaborations → code methods → tests.
Agile code engineering closes the loop: models drive code, code informs models, and both evolve together in tight, risk-reducing feedback cycles—ensuring architecture remains a living enabler of fast, high-quality delivery.
This completes the core techniques of Module 5. With these workflows mastered, you can confidently use UML as a productive, iterative tool that supports—not hinders—Agile software development.
